Sharp mx-m4501 banding at 2inches from trail edge
  • Petekj7
    • 21
    2 inches ( when trailedge leaves reg roller) there is a band(darker) in the image on card stock (not that thick)
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Sharp mx-m4501 banding at 2inches from trail edge
    Please, clarify the model for us - MX-4501 or MX-M450.
    • Petekj7
      • 21
      color 4501 thanks
      • ZOOTECH
        • 3375
        Even though the card stock is not that thick, the bypass tray is rated for Heavy Paper up 56lbs - the bypass tray must be set to Heavy Paper and is limited to 40 sheets.
        • Petekj7
          • 21
          Yes it is set for Heavy on machine and print driver.
          • DavePo
            • Jul 2008
            • 303
            I have seen this when the paper hits the fuser roller and hesitates for a milisecond. Try adjusting the fuser motor velocity for heavy paper in Test Command 48 sub 6.
