sharp mx3500n service mode
  • silverfox1
    Could someone explain how to enter service mode for mx3500n i need to clear error u210 it would be a great help thankyou.
  • JustManuals
    • Jan 2006
    • 9838
    Re: sharp mx3500n service mode
    Paul@justmanuals.com
    • mojorolla
      The Wolf
      • 2627
      The manual will give you everything you need.
      • lky1978
        • Mar 2009
        • 483
        Yes.manuals4you can help u.
        • stech
          you should get the manual from Sharp directly. Do you work for a official Sharp dealer? A simple web search will turn up the results you want in any case.
          • Viasens
            The corect error code is : U2-10
            You dont have the SM ?To acces the SM you need to be Sharp autorizat or call a Sharp dealer.
            I cant give you the acces codes. Sry
            SRAM user authentication index
            check sum error
            Trouble content User index information (basic data of user
            authentication) check sum error on the SRAM
            Section MFP
            Case 1 Cause 1) SRAM trouble
            2) Hang-up of the control circuit due to electrical
            noises
            3) MFPcnt PWB SRAM access circuit trouble
            Check and
            remedy
            Use SIM16 to cancel U2 trouble.
            • l2ps
              Anyone have any ideas on a sharp mx-2700 jamming only in duplex? Jam always in top right door.
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service Manual can now be purchased for $12.77 and downloaded immediately after payment from Just Manuals, The Internet's largest selection of manuals ~ Instant Downloads Paul@justmanuals.com
                • fbkhan3
                  • May 2012
                  • 421
                  first post,didn't introduce yourself.. an end user or a tech?
