sharp mx4500
  • bubba
    • Jul 2025
    sharp mx4500
    hi all have an mx 4500 with a vertical black line on rear of copy.first page only, have replaced k drum and dev units,primary and secondary transfer units.if you do a colour copy or black copy you get a vertical line.... on rear,any ideas....
  • davidweedon
    Re: sharp mx4500
    Have you changed the charger as well or just the drum, normally worn charger unit.
    • JustManuals
      • Jan 2006
      • 9838
      Re: sharp mx4500
      Paul@justmanuals.com
      • bubba
        Re: sharp mx4500
        hi whole drum unit replaced,main charger replaced.if you do multiple copies the line goes. it only appears on the first copy..
          • 23007
          Re: sharp mx4500
          This is caused by a LSU shutter which is either stuck open, has a broken spring, or is missing altogether. That line is the LSU firing and its normally blocked by a working (closed at the time) shutter.
          Remove the drums & developing units. Remove each shutter unit (1 screw each) and check them. There was a known batch of shutters which had a molding problem and they would sometimes catch on the bottom of the developing tank next to it, because there was a small raised lip on the rear side. A quick sandpaper of the top of the shutter unit stops this from happening.
