wiping Hard Drives
  • redserv
    • May 2010
    • 307
    wiping Hard Drives
    hello guys i have 2 clients that both want the HDD's in there Mfp formated, the rental contract is up, i just needed some advice on what format option i should use within simulation 62, one mfp is MXM453N and the other is MX-450N, thanks in advance.
  • bilyahn
    • Dec 2006
    • 1470
    Re: wiping Hard Drives
    I use 62-1 to wipe the hard drives. Takes care of the user's folders if they had any. Done this a couple of times and the customer seemed satisfied. I also go into the web interface and clear out all of their profiles and addresses. There's a sim for this but I like to do it from the webpage. I also reset the NIC and make sure the network settings do not have any entries other than the defualt. We have picked up serveral used copiers where the profiles and folders are still on the machine so I make it a point to delete this info on ours!
    Good luck.
    Bil
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Alternatively you can remove the HDD and connect it to a computer, assign a drive letter and format that way, if for whatever reason you can't/don't want to get it done via sims.
      Depending on customer's HDD usage it may even be faster than sim 62.
      • redserv
        • May 2010
        • 307
        yea thanks alot guys, think i need to get one off those Hdd jiggs so i can remove the Hdd from the MFP and format through windows.thanks again
        • Akitu
          • Oct 2010
          • 2595
          Manhattan makes a good USB SATA/IDE adapter for hard drives.
          • redserv
            • May 2010
            • 307
            thanks buddy, one more question though, how long does it usually take on average to completely format a HDD through Simulation?thanks again
            • Akitu
              • Oct 2010
              • 2595
              Depending on how much it was used, anywhere from 10 minutes to an hour is what I've experienced.
              • redserv
                • May 2010
                • 307
                ah ok thanks again pal,really appreciate the help, and thanks to everyone who had an input :P
                • Akitu
                  • Oct 2010
                  • 2595
                  No problem. Good luck with your HDD refresh.
                  • TennWalker
                    • Apr 2007
                    • 72
                    To totally eliminate the data so it is not recoverable, you might consider removing the hard drive from the copier and attach the drive to a Windows workstation. Using an application like DBAN, which is free to write a series of 1's and 0's to eliminate all data. The reformatting process will remove the directory structure from being seen by the average user. However, if the hard drive were to be removed by a skilled individual it would be possible to recover the data on the hard drive. I would not want you to be liable for any data that was found later on. Highly unlikely, but the remote possibility remains.
                    About DBAN | Darik's Boot And Nuke
                    Take care
                    I thought I was getting wiser as time went on... I now realize I am just getting older.
                    • divad2k1
                      • Sep 2010
                      • 147
                      Another option is to sell the HDD to the customer and let him do whatever he want with it (format,erase, destroy etc ..) This way you are a 100% sure you wont get in any trouble if data are recovered from the hard disk.
                      Or as Tennwalker said, use a third party software to erase the data.
                      • Arcking1968
                        • Sep 2011
                        • 39
                        A week ago i formatted a MX-453 using 62-1 it took an hour. Make sure to write the meter reading because upon formatting the meter reading also will reset. Luckily I print the configuration and return back the meter reading. After formatting i also update the firmware.
                        • mx270hb
                          Overworked, Underpaid
                          • Feb 2012
                          • 26
                          hmmm i 62-1 on all our refurb machines.. meters stay in tact.
                          • Akitu
                            • Oct 2010
                            • 2595
                            62-1 doesn't reset meters... Must have done 24-6 sometime before that.
                            Same for me as mx270hb said, 62-1 refurbs and meters stay intact.
                            • colgrimes
                              • May 2012
                              • 64
                              We normally do a 62-1 to reset the harddrive, reset the nic, 66-29 to remove destinations, and a 66-10 image memory clear.
                              if all else fails hand the HD to the customer so they can do what they want with it and bill them for a new one. if they are concerned about their data they wont care about an $80 bill, its better than spending $500 on a DSK.
                              colgrimes
                              The Printer Guy
                              CopierCollin.com
                              Hybrid Honest Sales/IT
