MXM363N noise
  • MHeon71
    • Oct 2008
    • 487
    MXM363N noise
    Have a MXM363N, where the client says it sounds like paper dragging. To me, it sounds like a gear or pinch roller just spinning. I have heard that sound on other machines, like the ARM455, and replacing the delivery unit resolved the issue.
    On this machine, I have replaced the delivery unit, cleaned and lubed the pinch rollers on the fusing unit, next to where the fuser web is. I have also removed the some drive gears on the right door to make sure it is not coming from there. I have not located noise and hope someone has.
    Any help would be appreciated.
  • bilyahn
    • Dec 2006
    • 1467
    Re: MXM363N noise
    Check the clutch on the paper feed assembly for tray 1. It's tucked in there on the rear side and drives the feed rollers on the paper feed section (part #32 in section 13). Had one of these make that kind of noise right out of the box but I would get random jam codes.
    Good luck.
    Bil
    • MHeon71
      • Oct 2008
      • 487
      Re: MXM363N noise
      Thanks for the tip. So far it is working.
