Sharp ARM256
  • GeorgeBest
    • Jul 2009
    • 525
    Sharp ARM256
    Got this problem with adjustment of the developer.
    Replaced new developer and run 25-2, after running this
    the machine gave an error said: EL error . . . .
    Seen this more on a ARM256 and an ARM316 ??
    Anyone seen this same problem on developer adjusting ??
    Thanks in advance
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharp ARM256
    Wait- It is coming.
    • DavePo
      • Jul 2008
      • 305
      Re: Sharp ARM256
      Have you taken out the toner concentration sensor and wipe it off ? Have seen this be the resolution on numerous ARM237, 257,277,317 boxes. Seems to be developer sticks to sensor and gives false reading. Clean it off and value should be correct.
        • 23006
        Re: Sharp ARM256
        EE-EL is an overtoned condition. In a couple of cases I've had to run a couple 30% fill pages before running the developer stir. A good stir should be between 89 and 101 ideally. =^..^=
        • oldrn
          • 166
          Re: Sharp ARM256
          DavePo's answer has worked for me. I have forgotten this step a few times when changing DV but I have been able to take out the DV unit, put the toner cartridge back into the DV unit and tip it forward enough to remove the sensor for cleaning. After cleaning the sensor, running the 25-2 did not produce an error.
