URGENT! Please Help - Print Through a 4 Switch Hub without internet?
  • Kirkc
    • Apr 2012
    • 42
    How can I Print to a Sharp AR-M350N Over a network cable but without Internet Access Or A Router Is it Possible?
    • 22996
    Re: URGENT! Please Help - Print Through a 4 Switch Hub without internet?
    Not with the switch, but with a crossover cable, sure. =^..^=
    • Flash
      • 378
      You should be able to do it with the switch. You have to assign the printer and the PC with a static ip address.
      • sandmanmac
        • 3978
        Absolutely. Internet access is not necessary to use a router and create a network. Set it up exactly as you would if there was internet
        • TheOwl
          • Nov 2008
          • 1732
          What you will need to do is to set an IP address into each piece of equipment such as the copier and the computers printing to it. Once you have done that, everything is as normal for setting up a printer.
          • sandmanmac
            • 3978
            I must apologize on behalf of all of us to Kickc because we forgot to say "you're welcome"!!......
