L4-30 on MX-2300N
  • delosangeles
    • May 2008
    • 274
    [Error Code] L4-30 on MX-2300N
    Hello everyone
    We have a client with a Sharp MX-2300N displaying Error Code L4-30 I checked the fans at above the Fuser and at the controller and the HDD , they all turn at start up so I am at a loss as to what is causing the Code. We mostly work on the Ricoh line of machines and we would be grateful for any input on this problem. Thank you in advance.
    Trade like a tiger sleep like a baby
  • brewster67
    • Jul 2011
    • 167
    Re: L4-30 on MX-2300N
    There are 9 fans on this machine, if you look at page 5-14 of service manual it will show locations. You can test the fans with sim 6-2. If all the fans work I would guess PWB problem. Hope that helps.
    • delosangeles
      • May 2008
      • 274
      We don't have the service manual but thank you for the info. Would you be able to post the page. Thank you very much.
      • delosangeles
        • May 2008
        • 274
        I just noticed that in Simulation 6-2 there is OZFM, POFM, & PSFM test options but no way to turn on HDDFM or CPUFM which happen to be the fans for the HDD and controller board. So how can one test those fan. Thanks for anyone's input.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • sheilathompson
            Originally posted by delosangeles
            Hello everyone
            The fan blades are normally the problem there is a new fan available. it may run interm. and continue to run but check the fans below the black toner there are 2 small fans. make sure they are operational.
            • delosangeles
              • May 2008
              • 274
              Are you sure? The Service manual is specific to error code L4-30 as being only the HDD fan or Controller PCB fan.
              • mojorolla
                The Wolf
                • 2627
                All fans can be tested using SIM 6-2:
                • delosangeles
                  • May 2008
                  • 274
                  [ATTACH=CONFIG]16703[/ATTACH]
                  Are you sure? I'm looking on page 7-15 of the Service manual and the HDDFM & CPUFM are not available to test.
                  Thank you, please confirm.
                  • mojorolla
                    The Wolf
                    • 2627
                    Allow me to rephrase, SIM 6-2 will test all the fans listed, and yes, I am sure. Why not remove the cover and see if it spins at power on...?
                    • rjh0566
                      • Aug 2011
                      • 14
                      Toner cooling fan should win out, its a small one i believe, Ive seen it several times, there was an update about installing 2 fans in place of one on the larger version mx3501-4501 because it was such a problem the first year of production. I dont remember if its in the test command. sometimes Sharp skips some of their component output test. always good to upgrade the firmware after installing a new fan, these were on backorder from sharp a few months ago. but should be able to get them now or using the vendor number written on the fan.
                      • delosangeles
                        • May 2008
                        • 274
                        I did and found them spinning but then they both slow down. Is that normally what they should be doing?
                        Thank you kindly for the help
