sHARP mxm350 Output tray selection default
+ More Options
Posts
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    [Misc] sHARP mxm350 Output tray selection default
    Hello all,
    I just serviced this Sharp MXM350 and everything worked out fine until customer says he wants the copies and prints delivered in the inner tray (area) of the machine, I found out that you can set this with the customer commands BUT as soon as I turn if off/ON again the copies or prints are delivered in the left tray again. Customer says it was "working fine" before servicing, which I didn't notice of course.
    Any hints are welcomed
    (by the way I read the SM back and forth and couldn't find any "permanent/defult" setting for this).
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: sHARP mxm350 Output tray selection default
    Originally posted by rapidocument
    Hello all,
    In the settings menu, under "Copy Function Settings" you'll find an option named "Initial Status Settings". In this sub-menu you'll find your output default settings to change the path to exit in the center tray. Hope this helps, good luck.
