sharp ar -m160 errror f2-04
  • RWAFA
    • Aug 2011
    • 68
    hi guys i have my machine sharp ar-m160,the machine is showing an error code f2-04 and toner sign,i changed the toner but the problem still persist,does any1 have an idea wht it could be,plse help my stranded.
  • harleyrider
    • Oct 2011
    • 348
    Re: sharp ar -m160 errror f2-04
    take the back panel off and check the conector that the toner crum fits into. It is mounted on a cheap ass bracket and it can bend backwards.
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • axyun
        • Aug 2007
        • 1323
        Try changing toner chip or cartridge. Frank/AP
        • bilyahn
          • Dec 2006
          • 1455
          Are you using OEM toner? Code is for an incompatible toner. Have had the connector come loose as mentioned above but that will normally just give you an add toner message.
          Good luck.
          Bil
