NOTICE: Users should expect a few periods of downtime this evening while we work on a few updates to the system.
hi guys i have my machine sharp ar-m160,the machine is showing an error code f2-04 and toner sign,i changed the toner but the problem still persist,does any1 have an idea wht it could be,plse help my stranded.
Are you using OEM toner? Code is for an incompatible toner. Have had the connector come loose as mentioned above but that will normally just give you an add toner message.
