arm 550n bypass jam
  • foudl
    • Mar 2010
    • 138
    arm 550n bypass jam
    I have frequent jam from the bypass (jam code mprd2_nm , mpfd2_sm), the paper path is the same as if it was from tray 2 except that there is never a jam from tray 2 , if someone have seen this prob please let me know
    • 23010
    Re: arm 550n bypass jam
    Perchance is your customer feeding a special coated media, that might coat all the rollers from the bypass to the fuser? The jamming starts in the bypass, but with enough of this media fed it will start jamming all over the place. =^..^=
    • foudl
      • Mar 2010
      • 138
      So according to you i should not pay attention to the jam code ?, i will have to double check they are using the bypass for large envellope,but it will jam even if i use normal paper , thanks anyway.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        You may just have some paper dust coating the sensors in question. Try cleaning them off and see what your results are.
        Also, these machines frequently get paper jammed behind the top 2 trays, take a look to see if there's any paper back there blocking the sensors (though typically you get the copier asking for paper in a fully loaded tray).
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
            • 23010
            So you want documentation? So here it is:
            Misfeeds (jam code MPFD1_S, MPFD_NM) from the bypass, (jam code MPRD2_N2) from tray #2 only. Flipped corners and skews into the finisher tray. Premature fuser roller failure. Unsuitable coated media (specifically posters) are fed through the bypass, coating the tires and horizontal path rollers and damaging the fuser rollers. Clean bypass tires and horizontal path rollers. Rebuild fuser. Advise against use of coated paper.
            This customer destroyed two fusers in less than one day. =^..^=
