ar-m451 print job
  • DINGO
    • 661
    ar-m451 print job
    >I friends
    i have some ar-m451n, and my question is because i have o big pdf document for print, and in one of them , only beguin print after the document is all 180 mb in spool, wait about 4 minuts, and i have another 3 in same place that the print job beguins imediatly?
    all of them as the same model, firmware version and optinals, and of corse same print drive versio?
    Somenone know something about?
    best regards
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: ar-m451 print job
    In your printer properties (devices and printers, right click printer, printer properties or properties, depending on windows version) under "Advanced".
    There are several options, either printing directly or spooling the print job. In here you can change the options to spool the entire document first or to start printing immediately.
    Hope this helps, good luck.
    • DINGO
      • 661
      thanks mate, but here all copiers are in the same contitions,
      thanks
      • DINGO
        • 661
        I mean, start imediatly is chosed in all copiers.
        • igi
          • 1507
          Hi
          do you use pcl-6 latest driver?
          • DINGO
            • 661
            No, i m using the pcl5 drive, is more fast them pcl6.
            Igi, in the same network i have four ar-m451n, all of them with same definition, firmware and so, and only one not start imediatly.
            Well, i m thikyng restart thd NIC.
            Regards
            • andreas182
              hi friend helpme please i need sst ir5000....thanks
              • igi
                • 1507
                Hi
                restarting nic is a good start,
                if does not help try swaping nic with another mfp
                ps reformat the h.disc and test memmory
                cheers
                • igi
                  • 1507
                  sorry friend
                  but i dont have 5000 infra-red stainless steel tables.
                  cheers
                  • ZOOTECH
                    Senior member of CRS
                    • 3378
                    WHAT???
                    • DINGO
                      • 661
                      good night friends
                      solved, was the option "counter bytes lpr"b in the print drive, must be disable for print faster.
