quick question on sharp ar m207
  • molson
    • 41
    does the exposure lamp stay on continuous as long as the copier is turned on?
    • 22997
    Re: quick question on sharp ar m207
    Yours may, but it's not supposed to. Only the really small Sharps do that, like the Jaguar and Puma series.
    The Pegasus series machines will light the lamp for a few seconds during initialization, each time the DF is raised, each time it comes out of sleep mode, and when you're copying or scanning. It sounds like a lot, but it's off most of the time. =^..^=
    • spanky
      • Sep 2012
      • 468
      adjust the pre-heat mode down. The exposure lamp will stay on until the machine goes into the pre-heat mode. This is done with the system settings in the energy management. I had an AR 208 melt the pad under the original lid because of this.
      • CopierTechofOmens
        Agitating Artificer
        • 268
        On the AR-M207 the copy lamp does stay on when it's not in use. You can disable this in Key Op. programs- Device Control- Copy lamp waiting setting. If you turn it off it will take longer for the first page to come out since it has to calibrate the scanner first.
        sigpic
