SHARP MX-2300
+ More Options
Posts
  • lenovos
    • Oct 2012
    • 140
    SHARP MX-2300
    Call started with yellow shadow randomly covering copy. There was lots of yellow toner in waste box. I pm'd copier changing drums and developer. I also ran auto calibration in admin mode. Copier printed out calibration page but when i put the page on the glass in the right direction i get an error saying copier can not read test patch. I then did color calibrations and all went well until i ran 46-24 and copier kept saying place test patch on glass. Also copies look great on glass but when you go to print certain colors are way off.
  • copyguy1
    • Jul 2011
    • 142
    Re: SHARP MX-2300
    I had one do the same thing when calibrateing. First look at the prim. xfer belt the transferroller on the back side became dislodged. Also when doing 46-24 make sure you are selecting factory . Hope this will help
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Re: SHARP MX-2300
      Had this same issue on a 2700. I had PM'd the drums and dev but nothing else because visually they appeared fine. It was not until I had replaced the primary transfer belt that the machine would accept the output calibration page, despite no visual difference in the page before and after. I had also attempted to clean my optics with no success. My transfer belt counter was double the expected life at the time of this incident.
      Hope this helps, good luck.
      • JustManuals
        • Jan 2006
        • 9838
        Re: SHARP MX-2300
        Paul@justmanuals.com
        • lenovos
          • Oct 2012
          • 140
          Re: SHARP MX-2300
          Thanks a bunch it was transfer belt. I have not torn it apart yet but replaced with one from another machine and worked fine.
          • Akitu
            • Oct 2010
            • 2595
            Re: SHARP MX-2300
            Glad your issue was resolved.
