sharp arm257 error code a0-01
  • advcopy
    • Jun 2012
    • 25
    i have a sharp arm 257 i have added a fax board to it however when i start it up i get the error code a0-01 which is a Security incompatibility error the board worked on the same model machince i toke it from i also replaced the board with other off a working machince my question is is there a reset that i have to do or what?
  • DINGO
    • 661
    Re: sharp arm257 error code a0-01
    incompatilbe fax board with the copier options.
    • DavePo
      • 305
      Does either machine have a Data security Kit? If one did and the other did not this would show.
      • ZOOTECH
        Senior member of CRS
        • 3375
        The security kit came with 3 ROMs, one for the printer board, the MCU, and the fax option. If you don't have the fax ROM, you would have to purchase another security kit to make the fax work. That is why when I install a security kit, I'll tape the original ROMs and any extra ROMs inside the covers of the machine for future use.
        • advcopy
          • Jun 2012
          • 25
          is therer a way to change them options
          • ZOOTECH
            • 3375
            You can order the MCU ROM and the PCL ROM, basically removing the DSK.
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • advcopy
                • Jun 2012
                • 25
                nks for the reply however i am an apprentice copier tech i've work on copier for under a year now. my boss doesnt know either what is it you can tell about these security kit is there a picture that can be supplied so i can know what it loks like so i can mve on from there. I would ever like to learn more about these
                ^_^ thanks for the info
                • ZOOTECH
                  • 3375
                  Run TC 22-10, that will tell you if there is a DSK; also, on the display there will be a "padlock" that indicates it has a DSK.
                  • advcopy
                    • Jun 2012
                    • 25
                    in the machine where are these boards
                    ok i found the msu but not pcl
                    the msu loks like twin of the the other board how can you tell one a non dsk msu to a dsk msu
                    • advcopy
                      • Jun 2012
                      • 25
                      alright from toying around with the copier setting and wacthing it do it thing i've deducted that the dsk was made copy protection deleteing its info of the copy job that was job now does it
                      dsk affect the address book or any other thing on the copier. now what is the reasoning behind of having a DSK on the copier and what are its pros and cons
