Sharp ARM-355
  • tcypy1961
    • 773
    Sharp ARM-355
    What causes misfeeding in the lower left side of the large capacity paper feed drawer? Paper stops and can be removed by opening the lower door. The paper has just entered half of the way into the paper feed most of the time and other times there may be two sheets but similar to how I described above, however the second sheet is just entering he fuser section. I have replaced the paper feed rollers on the left side but it didn't fix the problem. I also cleaned the paper feed clutch but this did not help either. Any help appreciated, thank you.
    • 23008
    Re: Sharp ARM-355
    What jam code? =^..^=
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: Sharp ARM-355
      Trust this, BC has an incredible data base; he will be able to
      help you.
      • tcypy1961
        • 773
        Re: Sharp ARM-355
        Where do I find this code??? Not a sharp tech.
          • 23008
          Re: Sharp ARM-355
          Whoa! I think I strained something. If my memory serves me it's: service mode > sim 22-3
          Sorry, you'll have to open your manual for the first part. I can't do everything for you. =^..^=
          • CopierTechofOmens
            Agitating Artificer
            • 268
            Re: Sharp ARM-355
            If I may cut in...
            To enter Simulation press #*C*
            sigpic
            • foudl
              • Mar 2010
              • 138
              Re: Sharp ARM-355
              You can print the misfeed with sim 23-2, you will have the jam code + time of jam .
