SR-M237 duplex printing from remote computer
  • Partsguy19
    • Jun 2025
    I have a Sharp AR-M237 that is hooked up to a Windows 7 64bit system directly using USB and shared via Windows sharing.
    Printing from the computer it is directly connected to, duplex printing works fine. When I try to duplex print from another shared computer (also Win 7 64bit) all I get are regular single page prints. I can go into print options and select duplex just like the connected computer but do not get duplex prints.
    When I installed the drivers on the remote computer, I just allowed it to use the drivers on the connected computer so they installed automatically.
    Any suggestions?
    • 22997
    Re: SR-M237 duplex printing from remote computer
    It could be that the memory upgrade is not configured at the other computers. Configuration problem.
    • bilyahn
      • Dec 2006
      • 1470
      Install the driver on the remote computer, go into properties and change driver to that driver. You should then be able to configure the printer to do duplexing.
      Go luck.
      Bil
      • Partsguy19
        Originally posted by bilyahn
        Install the driver on the remote computer, go into properties and change driver to that driver. You should then be able to configure the printer to do duplexing.Go luck.Bil
        Windows will automatically provide the driver from the primary computer to the shared computer. Are you saying install the driver directly on the remote computer instead of letting windows install automatically? I was going to try that next.
          • 22997
          Automatically installed, yes. Configured, no. =^..^=
          • bilyahn
            • Dec 2006
            • 1470
            That's what I would try.
            Bil
