mxb-402sc
  • byork
    • Aug 2025
    mxb-402sc
    sppd1_s jams, machine was on a dirty power line, i had the customer install a dedicated line but now i have these jams. i have replaced dspf control board but no luck. any suggestions?
  • mojorolla
    The Wolf
    • 2630
    Re: mxb-402sc
    That sensor is barley held in by the clips. Any jam removed backwards will knock the sensor out. Take the doc feeder apart and verify the sensor is seated properly.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Re: mxb-402sc
      Under the paper feed cover (sec #5, item #2 of the parts guide) there is a pwb with several connectors with cables that barely reach. I had one where the connector was not fully seated
      and it gave all kinds of intermittent jams and/ or non operation.
