Before realizing it we installed the color drum (C40NRS) into an MX-B402SC. Is in machine working but stated yield is only 30K vs. 72K on the C40NRB. Vendor shipped us wrong drum in error in case you're wondering how it happened...All I can see upon review here is that there is a small tab at the underside near the green 'latch' handle that should have prevented us from installing this drum (but didn't).
Any thoughts on yield issues or other problems? If they are truly interchangeable then I would pick the black drums for use in color positions if they are cross-compatible due to price. I'm assuming the actual drum is the same but don't have enough experience on this series.
