I am the same guy doing a PM soon on the Sharp MX-2700N and had also ordered a Primary Transfer Unit for it and decided to inspect it before going out to the customer. I see it is not coated per the instructions in the service manual. Can I coat it with toner from the customers toners in their machine when I get there? I don't have the white power and it is not in the box from P.R. Thank you in advance again! (and than you all for the previous answers)
Sharp MX-2700N New Transfer Belt does not have powder on it
Re: Sharp MX-2700N New Transfer Belt does not have powder on it
Sharp has changed their opinion on starting powders a couple of times of times over years. Titanium Hydroxide and something-something Stearate are the ones I have on hand. My advice is to get yourself some starting powder. In a pinch I've used yellow toner, but it's just not as good.
Sharp transfer belts do not come adequately powdered and you shouldn't count on it coming in a powdered condition. Also you must powder the entire surface of the belt, and rotate it through several rotations to make sure the blade won't wrap or stall the belt drive. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Thank you very much for the advice. I will try to get my hands on some or borrow some yellow toner out of the customer's bottle.Comment
zinc steartate is for selenium drums
kynar is for opc drums due to it being thinner
methuselah is supposedly the best and lubricates for a long time.
Precision roller sells this stuff at a decent price.Comment
I bet if your unit was ordered through SHARP it probably would have been powdered. How ever you got it through PR which is a 3rd party remanufacure.
I'd take a good look inside the belt unit to check if it was cleaned well, any debris stuck to the cleaning unit roller or the inside of the belt will give you a call back for "staple marks"Where the heck is my spring hook?Comment
Appreciate the additional advice. I have to apologize though, it appeared the belt had nothing on it when I looked at it initially, it was clean - but as it turns out when I got ready to apply the powder, I rotated the belt and saw that indeed it was powdered on the newly exposed belt. So I installed it as it was and it works just fine. Per one tech's advice, I did not install a secondary belt (machine has 275K), as it was advised these go much further than the suggested 200K.
New Question: During the interim of getting the back-ordered parts, the customer now is having a repeating of images in magenta (same image in black is fine), so on the page the graphic image is in full color but then it is repeated several times going up the page in magenta only. Can I assume that the magenta drum is now in need of replacement at 45K? I am thinkning the blade is failing and keeping the image on the drum. I know all three colors must be replaced at the same time if so.Comment
New Question: During the interim of getting the back-ordered parts, the customer now is having a repeating of images in magenta (same image in black is fine), so on the page the graphic image is in full color but then it is repeated several times going up the page in magenta only. Can I assume that the magenta drum is now in need of replacement at 45K? I am thinkning the blade is failing and keeping the image on the drum. I know all three colors must be replaced at the same time if so."You can't trust your eyes, if your mind is out of focus" --Comment
Thank you for that advice, however the customer is long way from me and I wouold like to be able to order the drums ahead of time and install on the same visit. Could you tell me if it is not the drum what else it could be? The the color image is repeated continuously but only in magenta, so it should not be the primamry transfer belt should it? (I did not replace the secondary belt). If it is something else possibly I could bring that part with me also. Thanks in advance!Comment
If the customer is a long distance you want to take everything possible."You can't trust your eyes, if your mind is out of focus" --Comment
Thank you for your question. The image repeats every 3 3/4 (3.75) inches. It is only repeated once and then the next image is repeated (only in magenta). So I am thinking the blade is not cleaning the drum for one revolution. Could you tell me if that the circumference of the drum?Comment
Sounds like a magenta drum to me. =^..^=If you'd like a serious answer to your request:
Thank you, I appeciate your confirmation of that.Comment
To answer your original question, I myself have used waste toner in a pinch when a belt needed to start and I did not have the titanium hydroxide. As already confirmed by Blackcat, it would appear that your magenta drum is in need of some attention. I would recommend rebuilding it yourself if possible, just to confirm that it's been done properly.
Never know what's up with the 3rd party rebuilds, can't guarantee quality.Cthulhu for president! Why settle for the lesser evil?Comment
