Prefix filename
  • markpote
    • Feb 2010
    • 9
    Prefix filename
  • mojorolla
    The Wolf
    • 2564
    Re: Prefix filename
    Enter all the presets for the job. Right hand side of the touch panel, touch the arrow. One the the choices should be save as a favorite.
    • markpote
      • Feb 2010
      • 9
      Re: Prefix filename
      Hi and thanks for the reply.
      I have already setup the preset buttons with all the other settings I need. What is not working as I need is the naming convention.
      If I set up the preset button it will always send the file as the name specified, so will overwrite the previous scan. I need each preset button to be prefixed with a code of my choice (ABC1_, ABC2_... etc) then have a unique identifier afterwards, preferably a date/time stamp.
      I hope this makes sense?
      Mark
      • bilyahn
        • Dec 2006
        • 1465
        Re: Prefix filename
        Mark
        If you go to the machine webpage under address book and click on the profile name I think there is an entry if you scroll down for file name prefix so you can edit it for each user that you want. Didn't get a chance to look yesterday and won't until later today to verify this.
        Good luck.
        Bil
