ARM257 ARP27 NIC lights flashing
  • hellcat
    • Jan 2012
    • 126
    Having this problem on this machine ARP27 installed , The NIC lights both green lights flash on and then off at 2 second intervals. Normally the bottom green light should be constant and only the top should flash. You can not access the copier web page or ping the copier. You are able to get to all the settings in the printer and SIM just fine.
    Things I have done. Swapped out the ROM chips with known good ones and swapped the scanner memory as well. I have ran the test commands to check memory and did the NVRAM clear. Nothing has worked yet.
    I am guessing I have a bad ARP27 but not sure if I should swap out the ARP27 I do not want to wipe my scanner product key out on accident because I do not have the register key to it.
  • danceswrabbits
    Re: ARM257 ARP27 NIC lights flashing
    I would probabally go with the p27. I think the scanner code "lives" on the main pwb so you should be good there. (however if I am wrong on that account, it is not that hard to get it looked up with the machine sn) good luck DWR.
    • bilyahn
      • Dec 2006
      • 1470
      Have you tried to reset the NIC card? You didn't mention it?
      Good luck.
      Bil
