Having this problem on this machine ARP27 installed , The NIC lights both green lights flash on and then off at 2 second intervals. Normally the bottom green light should be constant and only the top should flash. You can not access the copier web page or ping the copier. You are able to get to all the settings in the printer and SIM just fine.
Things I have done. Swapped out the ROM chips with known good ones and swapped the scanner memory as well. I have ran the test commands to check memory and did the NVRAM clear. Nothing has worked yet.
I am guessing I have a bad ARP27 but not sure if I should swap out the ARP27 I do not want to wipe my scanner product key out on accident because I do not have the register key to it.
