ARM-351U poor quality
  • Aungmyowai
    • Oct 2012
    • 5
    ARM-351U occur very poor quality in both copy and print.DV auto adjustment value sim-25-2 is too low.I changed DV unit two times within 6 month. I think that was unnessary and changing DV unit is not solution. Help me please.
  • bilyahn
    • Dec 2006
    • 1467
    Re: ARM-351U poor quality
    What is the final value? I've had them go into the 80's when replacing developer but still have good quality. What else have you tried? How many copies on the drum?
    Good luck
    Bil
      • 22929
      Light areas along the rear of the original/copy, within 30mm of the rear edge of the copy, print or facsimile at 94mm intervals.
      Something like this? Replacing the developing unit helped for a while. Leveling up the machine helped a little, but neither completely cured it. This machine was replaced, but I would have replaced the main drive unit next. =^..^=
      • igi
        • 1507
        hi
        i had high voltage p.w.b causing problems
        similar to yours, and check drum unit
        for cracked frame by toner transport spiral
        • xmasvn
          • Jul 2009
          • 70
          you can push a litte toner in dv and print (carefully not too much just 2 spoons again and again if that not good) when you have good quality so you run again 25-2 that will be better
          • lky1978
            • Mar 2009
            • 475
            i flashed imagistics firmware to these units and now my customers nothing to complain about printing quality issues.
            i faced this problem when flash to the latest sharp firmware, pcu 2.01.00 this version ll reduce toner density in dv box.
