Scaning
  • D&B Copy
    [Error Code] Scaning
    We have just installed a Sharp MX-2700n copier/scanner. Trying to setup network scanning. Getting a 'CE-OO' error. Have correctly entered ip address, subnet, and gateway, as well as domain and dns server info. Have created a unique domain user account for access giving full permissions to this user for the network folder where we will be saving scanned documents. Anyone have information on what to look for, or what we can check to determine where problem might be?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Scaning
    CE-OO is a generic network communication error. What server OS are you scanning to? Have you domain qualified the username (i.e. domain/username or username@domain)?
    See also: http://www.copytechnet.com/forums/co...er-dsc332.html
    • D&B Copy
      Re: Scanning
      We are running Windows Server 2008 R2 Standard 64-bit OS. Yes, I have domain qualified the username. I have tried both "mydomain\copier", plus have also tried "copier@mydomain".
      • spanky
        • Sep 2012
        • 468
        Re: Scaning
        Do you get the code only when scanning? Can you print to the copier? Can you ping the server from the copier?
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Re: Scaning
          The only two other possibilities could be either the firmware may be out of date (most likely) or you may need to lower the NTLM authentication.
          (Does 2008 default to Kerberos? If so a firmware update is definitely needed; just checking the firmware updates from 2010.)
          • mojorolla
            The Wolf
            • 2626
            Re: Scaning
            Type the network path into the "Run" box of Windows. If you cannot get to it from the PC, you have a permission issue and will not get the copier to work until permissions are properly set on the server.
            • D&B Copy
              Re: Scaning
              Yes, we only get the code when scanning. Printing to the copier from workstations works fine. Can you tell me how to ping the server from the copier? Thanks!
              • D&B Copy
                Re: Scaning
                Our copier technician said he had checked the firmware and it is the latest version. I will check the NTLM authentication. Thanks!
                • D&B Copy
                  Re: Scaning
                  Yes, I am able to get the network path from the workstation PC, so it appears the permissions is working okay.
                  • ZOOTECH
                    Senior member of CRS
                    • 3375
                    Re: Scaning
                    Log in as admin at the copier, go to network settings, page down and you'll find the ping command - type in the server's IP address.
                    • spanky
                      • Sep 2012
                      • 468
                      Re: Scaning
                      To ping the server from the copier go to the system setttings/ network settings/ ping command.
                      This is done on the touch panel of the copier.
                      • Dustin(WOP)
                        • 223
                        This is a firmware issue, sharp is working on the frontier series fix now. Then they will work on the older series of machines like yours. I had the same problem with the 2600 series. They released a firmware update and the problem went away..... so sharp is aware of the problem.
