MXM753
  • yorky
    • Jan 2013
    • 6
    [Dead] MXM753
    Hi first post on here hoping someone out there may have seen this.I have a MXM753U which will not power up, no display,fans come on for 30 secs then the psu voltages disappear. It will power up if HDD discoonected and displays HDD error.It also powers up if you try the emergency firmware procedure and completes firmware update but still wont power up when put back to default any help or ideas would be massively appreciated
  • bilyahn
    • Dec 2006
    • 1468
    Re: MXM753
    Check your memory modules. Take them out and insert them and try again or better yet swap with known good ones. When we had this happen it was because we were missing one of the memory modules.
    Good luck.
    Bil
    • Silvertoast
      • Feb 2010
      • 270
      Re: MXM753
      so if the hdd is connected it wont power up, but if u disconnect it it will power up but has hdd error?
      sounds to me u have a bad hdd, they will stop a sharp from booting up
      • yorky
        • Jan 2013
        • 6
        Re: MXM753
        Thanks Guys have tried Dimms but still no joy HDD ordered will keep you posted on outcome.
        • JustManuals
          • Jan 2006
          • 9838
          Re: MXM753
          Paul@justmanuals.com
          • Silvertoast
            • Feb 2010
            • 270
            Re: MXM753
            u can use generic hdd's it just has to be formated in ntfs cant be formatted in fat32. only takes a couple of minutes to format a new hdd. and is around 70 bux comapared to sharp 180
            • yorky
              • Jan 2013
              • 6
              Re: MXM753
              A Quick update on the solution to this problem it turned out to be a faulty PCU circuit board replaced it today and the machine booted up fine
