SHARP AR237 DISPLAY
+ More Options
Posts
  • pontiac
    • 420
    SHARP AR237 DISPLAY
    Have a copier display that is stuck with moving stars, I did the basics, reseat connectors reseat rom and still have the same issue. Thanks for replys.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: SHARP AR237 DISPLAY
    I've seen the ARMM9 for the fax cause this, pull the memory if installed, and try again.
    • pontiac
      • 420
      Thanks ZOOTECH, I removed the memory and still have the same problem. I just got a parts machine in that has a good main board, I will post results, any more suggestions please post. Thanks again.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • bilyahn
          • Dec 2006
          • 1470
          Remove the fax board completely and if you have the network print (ARP17) control board replace it with the standard print control board (if you have one), have had lock up issues with both boards at one time or another.
          Good luck.
          Bil
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            I've seen it on some of the larger MX colour machines, but leaving a flash drive inserted may sometimes cause the copier to try to boot from the flash drive, and will hang exactly as you describe.
