problem in fax kit
  • moha zaz
    • Jan 2013
    • 15
    [CQ] problem in fax kit
    hi all
    i have 2 SHARP ARM550 AND I Have a fax kit i'm tried to install it .
    in first machine after i installing the kit and card i can't send and receive i can not hear any tone of telephone line but if i receive call i can see message in printer screen
    the second machine after i installed the kit i can hear the tone of line and can call and receive calls but when i tried to send fax i can not and i got this message"max number of jobs have been already reserved pleas wait"
    but i can receive fax
    sorry my English not good
  • bilyahn
    • Dec 2006
    • 1470
    Re: problem in fax kit
    Try to clear your memory with sim 66-10. Might check to make sure that the fax setup is for the correct country as well. What is your ROM version for the fax and machine?
    Good luck.
    Bil
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Are both machines connected to the same fax line?
      • moha zaz
        • Jan 2013
        • 15
        Good luck.
        Bil
        thank's for replay
        after i cleared memory no thing change, i can't send message until now
        how can change the setup to my country?,and how can fet the rom version?
        thank you again
        • moha zaz
          • Jan 2013
          • 15
          thank's for replay
          no no i install the fax card and kit in one machine and when it did not work i move the card and kit to another machine
          • ZOOTECH
            Senior member of CRS
            • 3375
            Originally posted by moha zaz
            thank's for replay
            thank you again
            Test Command 66-2 will set your country code, and clear memory. TC 22-5 will give firmware version of fax.
            • moha zaz
              • Jan 2013
              • 15
              thank's
              my fax rom n1.060
              after i tried to set my country i did't get my country in the list YEMEN
              I tried to change the country to other1 after machine restart i see the code F6-21 ?
              • ZOOTECH
                • 3375
                thank's
                my fax rom n1.060
                Abnormal combination of the TEL/LIU PWB and the FAX soft switch
                F6 21 Phenomenon Display Lamp Message
                Details: Combination error of TEL/LIU PWB and software
                If the destination of the installed TEL/LIU PWB
                differs from that of the FAX soft switch, it is
                judged as an error.
                Case 1 Trouble position/
                Cause:
                The destination of the installed TEL/LIU PWB differs.
                The FAX PWB information (soft switch) differs.
                Remedy:
                Check the destination of the TEL/LIU PWB.
                Check the FAX PWB information (soft switch).
                Case 2 Trouble position/
                Cause:
                TEL/LIU PWB trouble
                Remedy:
                Replace the TEL/LIU PWB.
                What country code did you input? Where did the fax kit come from? You may have to input the country code where the fax kit originated.
                • moha zaz
                  • Jan 2013
                  • 15
                  judged as an error.
                  Cause:
                  Remedy:
                  Cause:
                  TEL/LIU PWB trouble
                  Remedy:
                  thank's for reply
                  when can get the country code of fax
                  i enter the code all 1 but at the end i enter 101 like this 11111101
                  • ZOOTECH
                    • 3375
                    thank's for reply
                    Yes, that is the code for middle and near east, if that's not working, try 11111011 for others.
                    • moha zaz
                      • Jan 2013
                      • 15
                      i changed the code Australia the error code hide
                      now how can use the fax to send and receive ?
