MX3140 Color Calibration
  • mikez
    • Oct 2012
    • 30
    We got a new MX3140 in the shop today to setup and can't find any color calibration procedures for brand new out of the box.
  • spanky
    • Sep 2012
    • 468
    Re: MX3140 Color Calibration
    The manual is available from the IDNC service site.
    Sharp-PC Service > Home > Passthroughs > Sharp-Start Login
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      There's a bit of common sense in the set up. First thing to do is always initialize your developer BEFORE loading toner. Set multi-paper sizes detect in the duplex and whether or not to count blank pages, set date and time, location code, right exit tray activation... Make sure everything is aligned with 50-22 and then do a 46-74 calibration. Not much to it... Same as any other Sharp.
      • mojorolla
        The Wolf
        • 2639
        I set one up the other day. Pretty much the same as the previous Aries and Virgo machines. I'm feeling saucy tonight so I'll give you the in depth version. Here is my setup:
        Calibration
        25-2
        50-22, do the ALL PHASE adjustment first. There is a screw for K on the new machines as well as the usual CMY adjustment screws.
        50-28, do the OC adjustment first. If not done first, anything scanned from the glass will be off.
        44-2
        44-13, this is the one with the jig
        44-6
        44-26
        Exit to reboot
        46-74. Use the recommended Hammmermill paper to calibrate, it does make a difference.
        63-8 + 67-28 : these point the scan and print targets to the target we just created.
        67-17, print memory flush
        65-1, touch pad calibrate.
        64-5, pattern 3. Shows the result of the calibration and your color alignment, the moment of truth.
        Update firmware.
        Settings: these are optional, just personal preferences.
        26-69 set to 1, toner prep message
        *26-38 value B set to 1. This is only on 4111 and 5111 machines. Print continue when the web reaches maintenance. This setting can buy you a few days on those long drive accounts, but don't wait too long, these fusers are poorly designed to say the least.<----saucy
        -Soft Switches
        SIM 55-1
        bit 9 sw8
        SIM 55-3
        bit 22 sw 5
        bit 9 sw 5
        These enable a maintenance and toner remaining bar graph on the touch panel. Very useful when calling in for PMs.
        Rinse and repeat.
        • Akitu
          • Oct 2010
          • 2595
          Calibration
          25-2
          44-2
          44-6
          44-26
          Exit to reboot
          Update firmware.
          -Soft Switches
          SIM 55-1
          bit 9 sw8
          SIM 55-3
          bit 22 sw 5
          bit 9 sw 5
          Rinse and repeat.
          Much more in depth than my own explanation. You saucy character, you!
          • ruben
            The New Guy
            • Oct 2012
            • 1204
            Doesn't the newer MX have a self-calibrating sensor? At least, that what I could tell by looking underneath. Also explains the lack of jig calibration instructions in the installation manual. (Either that or I have gone blind).
            • glewisme
              • Nov 2009
              • 240
              Do yourselves a favor guys. After running 25-2 run 50-28 first,then 50-22. I've seen the images wander all over on new machines out of the box doing 50-22 first. It's a tip I got from Dave Nipp at Sharp in NJ.
              • harleyrider
                • Oct 2011
                • 348
                Dave is a good no bullshit kind of guy. If he says do it that way it is probably the best way. I run into him once in a while in Romeoville when he is back.
                • mojorolla
                  The Wolf
                  • 2639
                  On machines before Aries and Virgo (2610-5111) I run 50-28 first. I run 50-22 on Aries and Virgo first ,but I have heard some different opinions on this. Sharp documentation actually say 50-28 should only have to be when adding paper drawers or an LCC. I always run ALL the 50-28 setups, no matter what the configuration of the machine.
                  I set another one up and noticed something odd. While using the recommended Hammermill paper, I started to get residual image and splotchy copies. Having rebuilt quite a few of these fusers, I pulled and inspected but everything looked fine. I then bumped the temperature down a few points, and ran again. The copies did the same things, residual and splotchy image. However, the good Hammermill paper had run out and the last two prints were on regular grade paper. The image was perfect, no flaws. I bumped the temps back to normal, went into Fuser Control, and set the machine to the 23-28lb. fuser setting. Did a full calibration with the Hammermill, and this time everything looked great. Ran 50 full color, good paper, all looked great.
                  So I now have the setup guys doing the Fuser Control setting at setup as well.
                  Dave Nipp was the best trainer I have had thus far at Sharp. I did the Hercules class with him. There was actual troubleshooting in his class. These new classes are too long, too dull, and the tools don't come out until Wednesday or Thursday.
                  He actually goes to Japan and gets to see all the cool stuff we only here about.
                  • glewisme
                    • Nov 2009
                    • 240
                    Yeah I know it says to perform only when addind additional paper drawers,but I've had it happen numerous times. So I have made it a habit.
