ar m550u printer option Disappeared
  • moha zaz
    • Jan 2013
    • 15
    [CQ] ar m550u printer option Disappeared
    Hi all
    i have sharp ar m550u after i execute 88-01 /02/03/04 to clear the fax memory the printer option hide and i can't print from network
    how can solved this problem ?
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: ar m550u printer option Disappeared
    Originally posted by moha zaz
    Hi all
    You have to re-enter the product key for the option.
    (To clear fax memory, use TC 66-2)
    • moha zaz
      • Jan 2013
      • 15
      how can i do that ?
      i mean how can i enter the product key ?
      • ZOOTECH
        • 3378
        how can i do that ?
        Log in as admin and go to Product Key, usually on second page of admin settings.
        • moha zaz
          • Jan 2013
          • 15
          AFTER i enter tc 56-1-2
          every thing back ok but when i restart the machine the printer Disappeared agin
          • bilyahn
            • Dec 2006
            • 1470
            Sorry to say this but that's what you get for screwing with the 80 series sim codes. Product key entry is basic level tech stuff! Softswitch settings in sim 56 will not fix your issue, enter the value as Zootech recommends and you should be golden.
            Good luck.
            Bil
            • moha zaz
              • Jan 2013
              • 15
              Good luck.
              Bil
              thank you all
              i can't got the Product key ,i got the serial number only
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                thank you all
                Unfortunately you screwed the pooch for yourself then. There's a reason why Sharp has gone through so much lengths to hide the extended sims in the Aries series...
