heya guys, My manager came to me yesterday and asked me to look into katun consumables for our sharp MFP's, what do you guys think of katun consumables for the new color copiers,i just really need you guys experience using katun, is it worth it? disadvantages and advantages maybe?thanks hope to hear from you guys soon.
whats your opinion guys
Re: whats your opinion guys
If you have to use non original toners Katun are probably the best, however yeild is always less than original dispite what they claim. Fusing temp problems can also be a problem on card or thick paper.
Parts such as fuser rollers seem excellent, in some cases better than original. -
Haven't used the color toners but from past experience with B/W toners I would NOT recommend their use. Have had a plethora of problems and a cornucopia of customer complaints regarding CQ. Doubt if they have improved their product even with a change in management.
Good luck if you do try them.
BilComment
Stay away from the toner and developer. All of it. Other parts perhaps. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
I do not like Katun. I have seen their cleaning baldes come UNGLUED form the bracket several times. Of course when that happens it takes the drum with it usually. I will admit that I have a major problem with Katun in that we tried their drums (Kyocera) and found in all four attempts that they produced a dark background on the copies. I called Katun to ask them about it and the guy from tech. support said "You must be installing the drum wrong." "First thing: I think I know how to install a drum. Second: how many drums have YOU replaced?" Answer: "Well, none." I rest my case. Haven't used them since.Comment
Stay clear of them! It will bite you in the ASS! I know from experience. Maybe try it on Legacy models first ( older ARM's ) stay as far away as possible from color . The developer is too expensive to make that mistake!Comment
