MX-C311 errors F2-58 & F2-39
  • Ingersoll
    • Nov 2008
    • 74
    [Error Code] MX-C311 errors F2-58 & F2-39
    Has anyone seen repeating errors F2-39 & F2-58? Replaced sensor, checked wiring cable but continues throwing errors.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-C311 errors F2-58 & F2-39
    From the manual...
    F2-39 Process thermister trouble
    Detail PCU
    Cause Process thermister trouble.
    Process thermister harness connection trouble.
    PCU PWB trouble
    Check & Remedy Replace the process thermister.
    Check connection of the harness and the
    connector.
    Replace the PCU PWB.
    Error cancel method Power OFF - ON
    F2-58 Process humidity sensor trouble
    Detail PCU
    Cause Process humidity sensor trouble.
    Harness and connector connection trouble.
    PCU PWB trouble.
    Check & Remedy Replace the process humidity sensor.
    Check connection of the connectors and the
    harness.
    So it looks like the only common ground between your two faults would be the PCU PWB. Have you checked it?
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • spanky
        • Sep 2012
        • 468
        I have had several of these, and I just clean the connection between the right door and the engine with alcohol.
        When you close the right door there is a connector at the top rear of the door that slides into a connector on the engine.
        • Ingersoll
          • Nov 2008
          • 74
          Now that is helpful information!
