how to network ARM207 MFP?
  • redserv
    • May 2010
    • 307
    hello guys i went to a client recently who has a ARM207 MFP with an ARNB3 nic card on the MFP,i was trying to get the ip address by holding down the black button on the ARNB3, but nothing is happening when i do so, is there a way to check the IP Adress on this copier?thanks in advance.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: how to network ARM207 MFP?
    From the manual:
    2. CHECKING THE IP ADDRESS
    There are several settings where the IP address must be entered or
    checked.
    To check the IP address of the machine, hold down the status button on
    the network expansion kit at least 2 seconds to print out a Printer Setting List.
    Caution: How to reset the network expansion kit
    To reset the network expansion kit, power on the machine while
    holding down the status button on the network expansion kit.
    Network scanner destination information and scanning settings
    will remain after the network expansion kit is reset, however,
    the network settings and network printer settings will
    revert to the factory default settings.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      To check status - hold down printer status button (above USB B connector) for 2 seconds. Status page will print out with IP address.
      To reset to factory defaults, hold down printer status button while powering up copier.
      To set or change the IP address you'll need the NB3 software CD. Under Administrator Tools -> NICManager select the NB3 and click Print Server Card Setup, enter the password and go into TCP/IP settings.
      These are quoted from the service manual, I don't have an NB3 on my remaining 207s - just a PRICOM3100.
      I know it's not likely to help, these things are quite unfriendly to someone who doesn't happen to have the software CD, but good luck!
      *Edit* got beaten to it by Zootech. That's what I get for being on the phone with Sharp support for over 20 minutes while diagnosing a machine problem and having this up with the text editor active. I'll leave this all here regardless...
      • redserv
        • May 2010
        • 307
        thank you very much guys for all the info, i did however try to hold that button down but nothing happened,i will go back to the client again, maybe i did something wrong.thanks again guys.
