MX2310 doc feeder drive motors
  • gwaddle
    • May 2009
    • 782
    Something I ran across the other day that I hadn't seen here and thought I'd share. I had a 2310 that jammed in the DF most of the time. The first thing I checked was for a clear paper path and sensor ops. I pulled the back cover and noticed that the shock mounts on both drive motors were coming apart. I don't know if this is going to be a common problem, but there are a lot of machines both color and b/w that have the same DF. Just thought I'd mention it.
    I know I should be ashamed of myself. Strangely though, I am not.
  • lky1978
    • Mar 2009
    • 483
    try to check/reseat the connector between feeder and machine. i faced same problem, losed connection when packed from factory.
    • bilyahn
      • Dec 2006
      • 1470
      Re: MX2310 doc feeder drive motors
      Thanks for the heads up! Haven't seen this yet but only have a couple of these units. DF is used across multiple generations I think so definitely something to be aware of.
      Thanks again.
      Bil
