Odor
  • tcypy1961
    • 773
    Odor
    I am working on a Sharp ARM-237 and there seems to be an odor coming from the copier. I believe it comes from the toner when it is baked on the paper in the fuser unit. The unit is either new or has been rebuilt. It has new rollers and such. I am wondering if this copier is known for having an odor?
  • Jammol
    • Jul 2012
    • 6
    Re: Odor
    I've had this happen with every copier I have worked on, even Toshiba. I think it's from the fuse rollers being new or fairly new. Happens all the time for my replacements. Give it a few weeks and it should go away.
    • bilyahn
      • Dec 2006
      • 1470
      Re: Odor
      There are several odors that you can get with these machines. If you are getting a "baked toner" or burnt smell I would look for a piece of paper stuck in the fuser that might be causing this. If it is a hot oil type of smell then that is normal for a new fuser and should go away after a few hours/days. If you are in a heavy dust environment you can have a slew of uninviting odors! Take your pick.
      Good luck
      Bil
        • 23008
        Re: Odor
        Good luck
        Bil
        Ditto that. Nearly every new fuser roller, regardless of manufacturer or model, will give you that delicate aroma of ... of ... of yesterdays pizza cooking to the bottom of the oven. It's pretty strong at first, but within a couple hours it will be hardly noticeable. I used to mention it to the keyop after I rebuilt a fuser, but everybody seems to already know now. Or they don't care. Just the same. =^..^=
        • Iowatech
          Not a service manager
          • 3930
          Re: Odor
          If the odor is temporary and coming from a fusing unit with a new hot roller, it is probably from the metal preservative on the new hot roller. Or, someone might have used the wrong grease when lubing the hot roller bearings, like I did a while back (that's one of my top ten smells I can do without for the rest of my life).
          Also, what's the condition of the area that machine is in? Is there anything like a fresh coat of paint on the interior of the facility, or something like a new process being employed in a nearby factory? I know that is a long shot, but a while back I had service calls for unexpected odors that were because of those types of issues.
          • MHeon71
            • Oct 2008
            • 489
            Re: Odor
            Ditto the other suggestions. I have had clients complain of musty smell as well, I replace ozone filters in that case.
            • mojorolla
              The Wolf
              • 2609
              Re: Odor
              Any time I do a PM or replace fuser rolls, I inform the customer of the faint odor. Sharps and Panasonics take 45-60 minutes to smell "normal". We had a brief bout with the 3rd party Panasonic rollers that prompted calls from customers worried there machine was about to catch fire.
              Have you tried different paper? Some cheap paper uses a filler in the middle which can have an odor. You could also try dropping the fuser temp.
              May also wanna check the lower half of the machine for a mouse nest and a few "berries". Found a few through the years.
