Noise
  • tcypy1961
    • 773
    Noise
    This Sharp ARM-237 is making a noise as the paper exits. There is a piece on the copier, where it exits, that shifts the paper as if trying to offset when sorting. However I am not sorting and this piece is constantly moving. Why would this piece move when sorting is not selected? Thank you for any help given.
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: Noise
    Is the output selected for "Offset"?
    • tcypy1961
      • 773
      Re: Noise
      Yes. I can turn it off manually each time before copying and the piece won't work; if I disable the part I disble sorting; I'm guessing this is all that can be accompished???
      Thanks!!!
      • ZOOTECH
        • 3378
        Re: Noise
        Thanks!!!
        Log into the Key Operator Programs, go to Copy Settings, then Initial Settings, and choose No Sort; it is probably set to Offset.
        • Toner Boy
          • Aug 2007
          • 357
          Re: Noise
          From time to time the offset motor/assembly will fail. By this point the delivery frame is probably baked from fuser heat and should be replaced anyway to eliminate many issues you will encounter, it contains the offset shift mechanism. Part is under $150 or so depending on source. CFRM-0038RS69
          • Toner Boy
            • Aug 2007
            • 357
            Re: Noise
            Well, they upgraded the part number (once again) CFRM-0038RS99
