AR-M451, distortion
+ More Options
Posts
  • DINGO
    • 661
    AR-M451, distortion
    Hello friends
    i have a ar-m451n that the print and copy in one side mode ,comes with a litle distortion, in all trays.
    I already replace the ps unit, and try adjust in the laser, but no sucess.
    Any help, i m glad, thanks.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-M451, distortion
    Originally posted by DINGO
    Hello friends
    Hi DINGO, can you post an image of the problem?
    • DINGO
      • 661
      ok mate, tomorrow in my office i do it.
      but is easy, imagine a square into the A4 paper ok., all margins are parallels at paper.
      so, when i print or copy is like i turn a litle the square into the paper, the margins no more are parallels.
      regards
        • 22997
        It sounds as though your treating this as an optical skew ... but the Tiger can also paper skew in many ways.
        Look at this post: http://www.copytechnet.com/forums/sh...arp-450-a.html
        • DINGO
          • 661
          Thank you mate.
          Best regards
          • DINGO
            • 661
            Hy friends
            this is a attached test.
            regardsprint test.pdfprint test.pdfprint test.pdf
            • DINGO
              • 661
              another test only one sidetest 2.pdf
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                Hi Dingo,
                How many copies does this machine have? Around 800k-1m the drive pack in these copiers tends to start failing and can cause skew and jamming from all trays.
                • bilyahn
                  • Dec 2006
                  • 1470
                  another test only one side[ATTACH]20023[/ATTACH]
                  Is this a sky shot? Or a copy of a sky shot?
                  • oldrn
                    • 166
                    Hello friends
                    Does that machine have a manual bypass tray? If so, copies are distorted from there also? How many copies on the machine? Have you checked for burs in the plastic guides leading to the PS rollers?
                    • DINGO
                      • 661
                      Hi friends
                      the issue was fixed, there wass the PSroller unit.
                      Infortunaly i have get tow bads for test to, and give me a wrong information,
                      so i get a new and all is ok.
                      thank you very much for everybody.
                        • 22997
                        Definitely a paper skew. It's extremely common to have those registration roller bushings seize up. Good catch. =^..^=
                        • DINGO
                          • 661
                          I mate
                          yes, is the point.
                          best regards
