mx-3100 please wait
  • mattwill1107
    • Aug 2008
    • 26
    mx-3100 please wait
    I have an MX-3100n that, when you boot up, the "please wait" message comes on (that usually flashes for a moment then goes away), but in this case, it stays on, and the machine is not operational. No error code. I can't get into SIM mode, can't really do anything. I've emergency flashed the firmware, and the update shows successful when I do it, but still the problem persists. One of our supervisors had a note about replacing the PCU flash rom. We did that, but still the issue. Any experience with this issue?
  • WilliamTucker
    • Jul 2012
    • 38
    Maybe harddrive?
    • bilyahn
      • Dec 2006
      • 1470
      Re: mx-3100 please wait
      Originally posted by WilliamTucker
      Maybe harddrive?
      Also try reseating the memory chips. I've moved them around to see if I could get the unit to respond if you don't have any spares.
      Good luck.
      Bil
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Go with the above answers, and if they don't resolve it check out the fuser. If the lamp cracks near the connector it can do this too. Check operations with sim 5-2.
        • wgrimes
          • Nov 2014
          • 2
          I'm currently fighting this issue with a machine. Did you find a resolution to this issue?
          • mattwill1107
            • Aug 2008
            • 26
            I apologize, I wish I had posted the resolution at the time. I went back through my notes and info, and I didn't find the final answer to what I used. I believe we wound up changing the PCU PWB, but I'm not 100% sure (it figures this is the one I didn't note). Sorry I wasn't more help.
            • wgrimes
              • Nov 2014
              • 2
              I believe found the cause of the issue. It's the USB conversion pwb ordering the part today.
              • mbcruzin
                • Aug 2013
                • 142
                Had this on a 2300. I did all the above but fixed with a new PCU PWB.
                This is interesting i will have to keep a look out.
                • Jack79
                  • Jul 2014
                  • 312
                  I will not tell you the solution but open front cover (where are toners) and close it back. Message Please wait should disappear (do it when you have got this message)
