AL-1642CS Flashing toner light after toner replacement and drum is lightly coated
  • Johnny 5
    [Misc] AL-1642CS Flashing toner light after toner replacement and drum is lightly coated
    I have an AL-1642CS that a customer brought into my shop and they stated that the add toner light was flashing. Upon inspection I found the following: Flashing toner light, drum lightly coated with toner and with the doors cheated and the drum unit removed toner is dusting. I checked the grounds on the drum itself, the drum shaft I put a little bit of conductive grease. Checked the charge unit and cleaned the contacts on the charge unit and the contacts inside the machine. Please help if you are able.
  • Wild Bill
    • Jul 2005
    • 774
    Re: AL-1642CS Flashing toner light after toner replacement and drum is lightly coated
    drum/ drum blade
    Izzy
    • Johnny 5
      Thank you for your input. I have replaced the drum and blade and I'm still getting the same results.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Sounds like a re-charged toner cartridge, or is it OEM?
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • BMSInc95
            • Sep 2011
            • 66
            Try another toner cart. and or the transfer unit is cracked.
