Greetings to all, I have a problem on a Sharp ar 5316 toner light comes on, the one you put in the car is new and original, I also replaced the developer and made โโthe simulation 25-01 but the indicator does not disappear, someone can help! thanks
Sharp Ar 5316 add toner
Tags: None
Re: Sharp Ar 5316 add toner
Check it 1st the Toner sensor(back side of the Toner Cartridge) and then go to TDK(in DV unit),, u also can clean this sensor and then go the programm mode and reset the copier one by one using 14 and then 16 and then 17.... Try it, I hope your problem will be solve.. -
