Sharp Ar 5316 add toner
  • tecnomarco
    • Jul 2011
    • 213
    Greetings to all, I have a problem on a Sharp ar 5316 toner light comes on, the one you put in the car is new and original, I also replaced the developer and made ​​the simulation 25-01 but the indicator does not disappear, someone can help! thanks
  • kashif
    • Apr 2013
    • 45
    Re: Sharp Ar 5316 add toner
    Check it 1st the Toner sensor(back side of the Toner Cartridge) and then go to TDK(in DV unit),, u also can clean this sensor and then go the programm mode and reset the copier one by one using 14 and then 16 and then 17.... Try it, I hope your problem will be solve..
    • bilyahn
      • Dec 2006
      • 1470
      I believe on this model that you clear the DV maint light with sim 42 and maintenance light with sim 20.
      Good luck.
      Bil
      • tecnomarco
        • Jul 2011
        • 213
        Hello Bill,indicator light does not turn off Toner
