sharp ar-m350n+
  • jrivera
    • Jun 2025
    sharp ar-m350n+
    in print settings the network setting is not displayed to enter any addresses. The ones that do show are default,interface and initialize, but not network settings. machines were lease returns from a customer that had three of them neither were connected. i have two that have same issue and one that does show the network settings option. any help is greatly welcomed. thanks
    • 22996
    Sim 66 SSW80 bit 8 to '0'
    Do you have all the necessary parts? Another poster here could not print a configuration page, then later commented that the hard drive and NIC had been removed.
    Perhaps network printing had been turned off so as not to display the CE-00 error. To turn it back on, set soft switch 80 bit 8 to '0', in simulation 66 (with or without AR-FX5).
    • pontiac
      • 420
      network settings
      after reseating nic cards network setting display came back. thanks for reply.
