AR-M550 Large Capacity Tray Feed Rollers...Neoprene?
  • Buddy
    • Aug 2009
    • 285
    Hi all,
    I went to a new customer's 550 and the LCC has what look like clear-ish, yellowish feed rollers. When I go to look them up, all I'm seeing are the standard looking, gray feed rollers.
    What am I missing?
    THANKS
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: AR-M550 Large Capacity Tray Feed Rollers...Neoprene?
    Originally posted by Buddy
    Hi all,
    What am I missing?
    THANKS
    Probably feed rollers from a Hercules machine; last longer with less jams. They are neoprene (sp?) material.
    • Buddy
      • Aug 2009
      • 285
      Ahhh, what's a Hercules machine? Curious minds want to know.
      • Silvertoast
        • Feb 2010
        • 270
        mx-850rt are hercules 850,950,1100 feed tires and are polymer type
        ar-620rt are the 550,620,700 feed tires and are rubber.
        the mx850rt work in the 550's and last longer, they also fit in alot of other machines
        • bilyahn
          • Dec 2006
          • 1470
          Do you switch the tire portion around or just install as is? I was just wondering since the MXM550 series feeds to the left and the MXM850 series feeds to the right. Have done this with some older rubber tires but was wondering if I needed to do this with the newer tires?
          Thanks for the info.
          Bil
          • Chr15tophe
            • Dec 2011
            • 42
            Whats the cost benefit per page?
            • Silvertoast
              • Feb 2010
              • 270
              Bil
              i just install them like like they are, if u think about it. on the herc's they feed to the right out of the trays, but in the lct the feed to the left but use the same tires through out. so shouldnt make any difference
              • Silvertoast
                • Feb 2010
                • 270
                dont know what the cost benifit would be for u or ur dealer, depends on what u can get either of them for. imo if a tire will last longer then u dont have to replace as much therefor saving $$$
                ar-620rt are rated at 100k
                mx-850rt are rated at 200k
