mx7001n document filing
  • chocolab
    • Jan 2012
    • 10
    hello all.
    i have an mx7001n that when customer goes to print document from document filing the buttons for "print and save" and "print and delete" are grayed out
    not allowing them to print the job. if they then print using the batch print then they can print. if the reboot the machine it will work again but will gray out again later. i updated firmware and formatted hdd but the problem still persist. This is an intermitten issue and is starting to annoy customer. any help is greatly appreciated. thanks in advance.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: mx7001n document filing
    Are they using job retention settings in the print driver?
    • MattL
      • Apr 2012
      • 97
      Does the machine have a data security kit on it?
      We had the same issue on a 6240 but also if we went from document filing to copy or scan the buttons were greyed out, we set the default home screen to document filing as that was what they used the most, changed refresh to 10 seconds and let it reset and the buttons became available.
      Issue has been raised with Sharp in the UK and they are looking into it, spent hours looking at it the other week.
      • chocolab
        • Jan 2012
        • 10
        yes they are using job retention in driver, and no there is no data security kit.
        • MattL
          • Apr 2012
          • 97
          We had the issue with the machine having a DSK on it so presumed it was to do with that, will be watching this topic and see what comes of it.
          • mojorolla
            The Wolf
            • 2671
            When printing to a Document Filing folder, set the job to Hold Only in the Job Handling tab
            of the driver. A user name should be entered into the Default Job ID field.
            Jobs that do not have anything in the Default Job ID field will use the user name of the
            person logged into the computer as the De
            fault Job ID when on a domain. Otherwise
            something must be entered to identify the user.
            If jobs were scanned into Document Filing, the
            same user name that is used at the computer
            should be used in order to print all of the user
            scanning into Document Filing, then have the
            user press the Default User button and then
            select Admin or User to print the scanned in jobs.
            • chocolab
              • Jan 2012
              • 10
              replaced hdd, havent heard back from them so i guess the hdd must've gotten corrupted somewhere.
              thanks for the replies.
              • chocolab
                • Jan 2012
                • 10
                should've never opened my big mouth. customer called back today with same issue.
                any one else have any ideas?
