Our engg installed a new machine MX-M452N. When we switch on the machine there is no display at all. He opened the back cover and he found that the fan is rotating. In the MFP PWB there are 3 + 1 Green LEDs which is in ON condition. In PCU PWB the one green LED light is blinking continuously. In SCN PWB one green LED is on. He tried to remove all the RAMS, HDD cables and reinserted again. So far no improvement. What could be the reasons and how can we rectify this problem? Kindly suggest.
MX-M452N No display in the machine
Re: MX-M452N No display in the machine
there might be an interface board too.... all to do with usbI fix copiers ...Well SortaComment
Paul@justmanuals.com
Re: MX-M452N No display in the machine...
i have had a similar issue on an mx-4112 this had no display this turned out to be faulty hdd and on the printer pwb there was a sd card which holds firmware on the printer pwb as well check if it has one that will need to be replaced then update firmware to latest version including the watermark. hope this might help.Comment
