HDD
  • Lynn56
    TECH
    • Jul 2012
    • 21
    [Misc] HDD
    Where is the HDD located in a Sharp AR-M350?
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: HDD
    It may not have one, check with TC 22-10.
    • Lynn56
      TECH
      • Jul 2012
      • 21
      Re: HDD
      It is not running and is a junk machine...just trying to remove the HDD for security reasons and I am not trained on this machine.
      • ZOOTECH
        • 3375
        Re: HDD
        If it has a HDD, it will be on the MFB pwb accessed by removing 5 screws where the doc feeder cable attaches.
        • Lynn56
          TECH
          • Jul 2012
          • 21
          Re: HDD
          I am not seeing anything on that board so must not have one....Thank you very much.
          • Silvertoast
            • Feb 2010
            • 270
            Re: HDD
            the hard drive is accessed thourgh a side metal door on right side of machine. remove finisher/mailbin if it has one, then remove ribbed side panel by taking out the two screws/bolts that are sticking out, thin u will see a metal door that is removed with 1 screw . then one more screw behind that and the hdd will come out in a cradle.
            • Silvertoast
              • Feb 2010
              • 270
              Re: HDD
              if the copier is not a N model or did not have a print option installed it will not have a hard drive
              • Lynn56
                TECH
                • Jul 2012
                • 21
                Re: HDD
                Looking behind finisher and panel and no HDD...Thank you....I do have another machine [Sharp AR-337] looking behind back panel and not finding the HDD there either....Is that where it should be found?
                • ZOOTECH
                  • 3375
                  Re: HDD
                  The Cougar series had the HDD under the original glass.
                    • 23009
                    Re: HDD
                    On the Cougar (AR-337) you'll find the HDD under the lens cover.
                    On the Tiger:
                    (AR-M350 and AR-M350U) do not have the hard drive originally, unless added as an option (right on top of the MFP board).
                    (AR-M350N) will have the HDD on the MFP board out of the box.
                    Damn you Zootech. You did that on purpose, didn't you! Didn't you!
                    • Silvertoast
                      • Feb 2010
                      • 270
                      Re: HDD
                      correcting my post..... 350 450 is on the mfp board. i was thinking of the 355 455 which is where i stated. sorry for the confusion, thanx zootech for the correction, been along day
                      • Lynn56
                        TECH
                        • Jul 2012
                        • 21
                        Re: HDD
                        On the Tiger:
                        On the 337 I found the HDD under the lens cover.....never would have thought to look there...Thanks for the info!
                        • JustManuals
                          • Jan 2006
                          • 9838
                          Re: HDD
                          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                          Paul@justmanuals.com
