Transfer belt
  • vlad_robas
    • Oct 2006
    • 225
    Transfer belt
    Hello,
    i had a problem with an MX-2310, on black copy or print image was poor on the lower part of the page, u can see on attach
    i try the transfer unit on another machine, MX-3111, and is the same problem
    i changed the belt on that unit and is the same, only on black
    im thinking at the roller spring maybe?
  • harps05
    Field Service Engineer
    • Mar 2012
    • 112
    Re: Transfer belt
    I would check the main charge unit.
      • 23006
      Re: Transfer belt
      Why do you think that it's a transfer problem? Have you emergency stopped the machine and examined the latent image on the transfer belt?
      What is the interval on the pattern? It seems awfully short for a transfer belt. More likely, black primary charge, black transfer roller, or black developing. =^..^=
      • vlad_robas
        • Oct 2006
        • 225
        Re: Transfer belt
        I don't know if u understud that i moved the unit from the machine where it first did the problem (2310) to 3111 and then to 2610 and the problem moved with the transfer unit. And is only on black, black pressure roller inside the unit is where the unit bends itself for removal of the belt.
        • mojorolla
          The Wolf
          • 2606
          Re: Transfer belt
          Sharp uses those tiny white collars to hold the FTRs in place inside the belt. Remove the belt and inspect the black FTR roll. Also ensure the cam is working and the FTRs move properly. You can test the action of the FTRs in SIM 6, transfer load check. All on, all off, or black only.
          I would also tend to agree with my colleagues, the sample indicate DV, charge or drum. These things are known for DV pull.
          • JustManuals
            • Jan 2006
            • 9838
            Re: Transfer belt
            Paul@justmanuals.com
            • vlad_robas
              • Oct 2006
              • 225
              Re: Transfer belt
              I had time today and take the unit apart again and i soo the Transfer roller bearing F being worn, very worn so i placed a order.
                • 23006
                Re: Transfer belt
                Congratulations vlad. =^..^=
                • vlad_robas
                  • Oct 2006
                  • 225
                  Re: Transfer belt
                  I got my part today, NBRG0945FCZZ and it fixed my problem.
                  Other 2 colors that are using the same colar are worn too but not as much so I replace those too.
                  I'm suprised I'm the only one having this problem.
                  Have a nice weekend.
