Sharp Ar 5631 ADF problem after unplug socket from machine
  • williekriss
    • 39
    Hi everybody,whats the problem for this machine when after i unplug the socket from the machine.after that plug in now the ADF showing paperjam but actually no paper.Thx for advice
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp Ar 5631 ADF problem after unplug socket from machine
    If you replaced the ADF plug while the machine was still energized then you will need to replace the board located on the ADF. Did this one time myself!! Also check for bent pins on the ADF plug.
    Good luck.
    Bil
    • williekriss
      • 39
      Originally posted by bilyahn
      If you replaced the ADF plug while the machine was still energized then you will need to replace the board located on the ADF. Did this one time myself!!Good luck.Bil
      I did switch off the on/off button on the machine,or u mean i need to switch off the main switch?
      • bilyahn
        • Dec 2006
        • 1470
        If this machine has 2 power switches then yes, there is always power to the boards unless both are turned off. In fact whenever messing with boards or optional equipment plugs I would recommend you unplug it from the wall just to be safe.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Be safe; always unplug electrical equipment. Even when unplugging an option like DF you can encounter electrical dangers, also give the machine time to completely release its charge before plugging the DF back in. Not having worked on this model there is little help I can give except the generic stuff, firstly check that the sensors are clean and clear, and that there is no jam. (You would be suprised how many times someone has cleared a jam only to have another piece broken off inside.) If the sensor is photoreflective, make sure the cavity it looks into is clear. (If it has one.)
            • 23008
            Originally posted by ruben
            Be safe; always unplug electrical equipment. Even when unplugging an option like DF you can encounter electrical dangers, also give the machine time to completely release its charge before plugging the DF back in. ...
            Agreed. The damage usually result when you plug the accessory back in, while still live. If you do something stupid like unplugging a live accessory, don't plug it right back in! Turn completely Off, Unplug the copier from the wall, wait 10 minutes, then plug the accessory back in. It may survive.
