blank copies sharp mx-m350
  • javier4065
    • Feb 2007
    • 251
    Hello, the copier makes blank copies , what can I do to solve it, thanks friends.
  • harleyrider
    • Oct 2011
    • 348
    Re: blank copies sharp mx-m350
    new developer unit, new developer drive unit, new transfer corona, new lsu, new power supply, new acpower supply, new optics ass'y,new toner, rtfm. I would start with thes things.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • spanky
        • Sep 2012
        • 468
        Is there an image on the drum if you stop the machine during the copy process?
        If yes then look at the transfer or the HV unit supplying the transfer charge.
        If no image then look at the developer unit to verify the mag roller has a good brush of developer material on it.
        Also check that the drum is turning, put a mark on the front flange of the drum and see if it moves when you try running a copy.
        If these are good you may also check the drum ground and last it could be the LSU.
          • 23006
          The only time I've gotten blank images on the Tiger or Jupiter it was caused by a damaged developing roller. The drive end had separated from the cylinder: the cylinder wasn't turning. =^..^=
          • bilyahn
            • Dec 2006
            • 1470
            I hate to be the smart ass here but is your original face down????
            Happy Father's day to all those Big Daddy's out there!
            Bil
            • ZOOTECH
              Senior member of CRS
              • 3375
              Bil
              Blackcat - I think you may have competition with your "master of the obvious" signature.
                • 23006
                Since javier4065 hasn't really tried anything yet, I think the smart-ass response is most appropriate.
                Thanks for stepping Bil. I missed the opportunity. =^..^=
                • bilyahn
                  • Dec 2006
                  • 1470
                  More than happy to help out when I can!!
                  • javier4065
                    • Feb 2007
                    • 251
                    thanks friends, the problem was the transfer unit, it was broken.
